s300 data logging issues
drvtec99
Post by drvtec99 »
-11590
-2.2.4.0
- 99 civic si
- p28
- having issues with data logging/connectivity with hondata
using bkr7e plugs, switch back to stock dizzy, swapped usb cables and used different laptops and getting the same issues with data logging as attached
Re: s300 data logging issues
Turn off on-board datalogging. This must be turned off when datalogging using the laptop.
drvtec99
Post by drvtec99 »
disabled onboard logging, now it is losing connectivity at random on two different laptops. i have checked grounds on tranny, thermostat, and are good and solid. changed out dizzies and still experiencing connectivity issues. Any other thoughts on this?
What spark plugs are being used?
drvtec99
Post by drvtec99 »
Spunkster wrote:What spark plugs are being used?
ngk bkr7e
Who sockedted the ECU and has the J12 been cut in the ECU?
drvtec99
Post by drvtec99 »
Spunkster wrote:Who sockedted the ECU and has the J12 been cut in the ECU?
ecu is from phearable and yes
i'm trying to source another s300 setup to test that but haven't had luck yet
Do you have a friend that you can try your ECU in their car?
