Ecu powers up but kpro doesnt.
Kairu2010
Post by Kairu2010 »
Alright, yesterday I got my car back from exhaust shop it ran fine, stopped at the house. Couple hours later went to the bank.
On the way I realized it wouldn't rev past like 3k rpm. Then I tried to connect the laptop and all it said in the corner was : error/ ignition off
Although it was on. Looked at the ecu and there is no red or green light lit up when the car is running or when the ignition is on.
I was told to check grounds and fuses which I did. But why would the car start if the ecu wasn't getting power. Obviously it is because I can drive it. Is my kpro board messed up?
Re: Ecu powers up but kpro doesnt.
What is the serial number on the K-Pro board inside the ECU? From Help, About, what version of software are you using?
Kairu2010
Post by Kairu2010 »
Hopefully this has what you are looking for.
You have not said what version of software you are using
Kairu2010
Post by Kairu2010 »
The latest version of kmanager. I also tried to beta version and installing/unintelligible use drivers.
With the beta version of software, what is teh exact error you are getting?
Kairu2010
Post by Kairu2010 »
Thesame exact thing. Kmanager does not recognize when the ignition is on. No red or green lights at all coming from the kpro board
With the USB plugged in, what does it show up as in the Windows Device Manager?
Kairu2010
Post by Kairu2010 »
Shows up as kpro ecu with no exclamation point or anything. Shows up as it should.
Using the current beta version and everything plugged in what does it say in the lower left hand corner of the KManager software?
Kairu2010
Post by Kairu2010 »
Drivers installed | error | ignition off
With the K-Pro plugged in please go to Help and click on send information to Hondata support. include a description of the problem.
Kairu2010
Post by Kairu2010 »
I send it just a minute ago. Im trying to figure out why it would say error. before I even turn the ignition on
Have you tried this with a different laptop or desktop computer? If not, can you?
Kairu2010
Post by Kairu2010 »
I have tried with 2 laptops and a different usb cable. installing/uninstalling different kmanagers and usb drivers.
