K manager disconnect
Felipito
Post by Felipito »
K manager disconnect after a few seconds when dattaloging, new spark plugs, re route ground to valve cover, kpro has insulated tape, kmanager is up to date. When this happen i have to disconnect and conect the usb cable and start again, i notice this happen close to 6000 rpm. I dont know whatelse to check.
Re: K manager disconnect
What is the part number of the spark plugs you are using.
Felipito
Post by Felipito »
ngk laser iridium ifr7g-11ks
Felipito
Post by Felipito »
03 rsx type s stocks engine, rev hard turbo kit60a/r turbo, 750rc injectors, hondata boost controller and map sensor 4 bar, no cat/ 5 zigen exhaust, kpro 3#12106, 37820-prb-a06/ 2068-602146.
When dattaloging on part trottle everithing is ok but when dattaloging on wot kmanager disconnects like around 6000rpms.
Ground is on valve cover new spark plugs laser iridium ifr7g-11ks.
Rev hard cal. From hondata, car was runing good but when i install the boost controller stars back fires, then i install the hondata map sensor and fuel cuts at 5 or 4 psi, but the main problem is tha kmanager disconection, i cannt dattalog passing 6k rpms and i want to fix this problem before dyno tuning
Felipito
Post by Felipito »
I brought kpro from club rsx.com. New. My kmanager version 3.2.5.0 and weather is 110degrees
You have not posted your calibration
Felipito
Post by Felipito »
sorry
It appears to be too lean and it is lean cutting because of lean protection. I would highly recommend getting this tuned before you damage the engine running too lean.
Felipito
Post by Felipito »
A dyno tunin will fix this issue
