k20a2 PLM RH/CAI/IMG/Mugen Twinloop exhaust
Hello all, I am sending my reflashed ecu to upgrade to kpro. I have a kpro ecu from my other car to use so pretty much need a map for me to drive home safely and get it tune after. Any suggestions would be very appreciated. Thanks in advance.
Re: k20a2 PLM RH/CAI/IMG/Mugen Twinloop exhaust
use the toda headers calibration that comes with the kproskygtr wrote:Hello all, I am sending my reflashed ecu to upgrade to kpro. I have a kpro ecu from my other car to use so pretty much need a map for me to drive home safely and get it tune after. Any suggestions would be very appreciated. Thanks in advance.
2002 DSM ACURA RSX TYPE-S / K-PRO / PWJDM INTAKE / OBX V2 HEADER / HASPORT MOTOR MOUNTS / INGALLS ENGINE TORQUE DAMPER / K-TUNED BILLET SHIFTER / SCHROTH RACING HARNESS / ENERGY SUSPENSION
Unless your car has I/H/E i wouldnt use that map. It is still a strange setup for even a built motor. If you need a tune i can help you out.protoge91 wrote:use the toda headers calibration that comes with the kproskygtr wrote:Hello all, I am sending my reflashed ecu to upgrade to kpro. I have a kpro ecu from my other car to use so pretty much need a map for me to drive home safely and get it tune after. Any suggestions would be very appreciated. Thanks in advance.
yeah youre absolutely right that cal is weird A/F...i wonder where it came from and exactly what setup it works best ontkane4389 wrote:Unless your car has I/H/E i wouldnt use that map. It is still a strange setup for even a built motor. If you need a tune i can help you out.protoge91 wrote:use the toda headers calibration that comes with the kproskygtr wrote:Hello all, I am sending my reflashed ecu to upgrade to kpro. I have a kpro ecu from my other car to use so pretty much need a map for me to drive home safely and get it tune after. Any suggestions would be very appreciated. Thanks in advance.
if you have stock IM, I have a good kal floating around here somewhere.
02 RSX Type S (sold)
11 TSX Tech (daily)
Hit me up for free Hondata Help. Over 4K downloads on my famous GSR Tune!
11 TSX Tech (daily)
