K-Pro S2000, switch for start datalog...
dduaime
Post by dduaime »
Hello, I received my K-Pro today and I look at how to setup it on my S2000 2001.
I would like to using a manual switch for start and stop my datalogging but I do not understand how.
In K-Pro software, it gives pin to connect a switch but are those of a RSX ecu.
Someone could help me by giving the equivalent of a s2000 ecu. I do not want to break something...
Re: K-Pro S2000, switch for start datalog...
The S2000 pins are listed in the help file.
http://www.hondata.com/help/kmanager/ecuconnectors.htm
eg E16 PSP (RSX) = A26 (S2000)
dduaime
Post by dduaime »
Ok, Thanks.
If I connect the switch for start and stop datalog on PSP, I have to cut the wire that goes into ecu A26.
Wire on pin A26:
Switch open = datalogging on
Switch to ground = datalogging off
And the ecu will not have the PSP signal, its will not disturb?
dduaime
Post by dduaime »
nobody can answer?
Usually it is best to remove the pin from the ECU plug (and insulate it). That way you can always return it to stock without cutting / joining wires.
Then A26 should be wired to ground via a switch.
