SManager 2.3.2
SManager 2.3.2
V2.3.0 (14 Mar 2014) V2.3.1 (15 Apr 2014)
  • [S300 V2] Fixed calibration download.
V2.3.2 (18 Apr 2014)
  • [S300 V3] Fixed analog input on board datalogging.
V2.3.3 (14 May 2014)
  • [S300 V3] Fixed flashing red light upon power on.
Johnny_9
Re: SManager 2.3.0
Post by Johnny_9 »
1) Does S300 V3 have an exportable datalog for Knock?
2) If exportable via DDE, can you provide guidance/links as to how this would be done?
Re: SManager 2.3.0
1. No. The knock on the OBDI ECU is mostly handled by the knock board, so you only get to see the retard anyhow.
2. Yes. See the help http://www.hondata.com/help/smanager/dde_server.htm and the example code in google code.
Johnny_9
Re: SManager 2.3.0
Post by Johnny_9 »
Thanks. Any recommended tools/links to write a CSV file (that can be imported to excel) from DDE?
9queSt
Re: SManager 2.3.0
Post by 9queSt »
Does the new software work with v2?
Re: SManager 2.3.0
9queSt wrote:Does the new software work with v2?
Yes.
VitViper
Re: SManager 2.3.0
Post by VitViper »
Any plans to allow digital inputs to be used for the advanced protection??
Re: SManager 2.3.0
No plans, but I'll look to see if it is possible.
Johnny_9
Re: SManager 2.3.0
Post by Johnny_9 »
How do we get a CSV file for the all the DDE Server data (like when we use the Datalog>Export in the "Graph" window)?
VitViper
Re: SManager 2.3.0
Post by VitViper »
Hondata wrote:No plans, but I'll look to see if it is possible.
That would be awesome -- I have been looking at converting to all the PLX goodies using the digital feed.
Also -- a boost control adder like the ignition/fuel tables for flex fuel would be awesome. It would be fun to flex fuel the DC2, but no point til I can turn the boost up with ethanol content...
Re: SManager 2.3.0
I would rather have manual control of the boost (via the current high/low boost control) than letting the ECU device how much power to make. Ignition & fuel adjustments yes, but the idea of the power level changing day to day would be dangerous in some situations.
aria
Re: SManager 2.3.0
Post by aria »
"Shift+F1" button to go to normal table doesn't work, it goes to Hondata Guide page (SManager Help Contents). it didn't happen on prev software version and i didn't change any keyboard shortcuts as well.
Re: SManager 2.3.0
This has been fixed for the next release.
VitViper
Re: SManager 2.3.0
Post by VitViper »
Going through a datalog that I recorded while linked via bluetooth... as I move the cursor position, none of the values in the 'Sensors' window update....
Re: SManager 2.3.0
Works for me. Was it a laptop datalog or an on-board datalog?
