Fuel Trim
keithd2959
Fuel Trim
Post by keithd2959 »
Hi!
I was wondering if there is a way (using Hondata Flashpro) keeping FUEL TRIM (Honda S2000 - 20006model) as is during the transition period between CLOSED and OPEN LOOP instead of always changing back and forth?
Any ideas guys?
Re: Fuel Trim
Can you give an example?
keithd2959
Re: Fuel Trim
While accelerating in closed loop i am having a fuel trim of -25%, then when the closed loop changes to open loop the afr goes down to around 10 and the engine starts misfiring. Instead of changing the fuel map i was wondering if its possible that the ecu clamps that fuel trim and keeps it even during the open loop.
Re: Fuel Trim
I meant a datalog, but if you're getting a -25% fuel trim then you need to get it tuned. The fuel tables, at least in that spot, are far too rich.
keithd2959
Re: Fuel Trim
Thanks for the info. I think that i have some excess fuel pressure so i will try to adjust the fuel pressure first before i change the fuel map. I will send you a data log shortly. Thanks
keithd2959
Re: Fuel Trim
Please find attached datalog as requested
Re: Fuel Trim
It needs fuel tuning. Why is the speed a constant 78 mph?
keithd2959
Re: Fuel Trim
It is constantly 78mph as the engine is on an ex F3 car and it has no speedo and Honda gearbox with sensors,so we have a small adjustable circuit to simulate speed for Vtech to engage
