Migrating from KPro dual ECU harness setup to FlashPro
FlashPro questions & answers specific to the 2007-2008 US TSX
evenq
Post by evenq »
I'm currently running the old dual ECU Kpro setup on my 2005 TSX and I'm planing on migrating to FlashPro. I have a few questions on what will be needed to make this conversion. Can my current KPro cal be converted to a FlashPro calibration so I don't need to get a re-tune right away? If I remember correctly I had to swap out my O2 sensor with a 04-05 D17 Civic's o2 in order to use KPro with the dual ECU setup. I'm assuming I will need to swap the O2 sensor back to the stock TSX O2? Is there anything else I should know about before I start this migration? I've purchased a 08 TSX ECU and will be purchasing FlashPro with the CAN kit soon.
Re: Migrating from KPro dual ECU harness setup to FlashPro
What year is your TSX? The calibrations are different and can't be converted. You'll need to switch back to the stock o2 sensor.
evenq
Post by evenq »
Thanks, it's an 05 TSX but did an 04 ECU swap.
