afr logging?
FlashPro Manager software
eastbethelboy
afr logging?
Post by eastbethelboy »
ok im new to tuning fpm. I have tuned s300 with great success and im new to kseries.
I got everything connected to the laptop. data logging works.
aem wideband connected to secondary o2 port. white wire to b29 (also tried ELD)
my settings in lambda overlay is set to wideband analog
secondary o2 disabled.
tried ELD disabled for (eld pin)
wideband voltage input was set to egrl (pin b29)
im trying to log my afr in the tables while driving and I cant seem to log any afr at all.
im not sure what im doing wrong here but nothing seems to be working. can someone help me get started.
Re: afr logging?
Why the -2V offset? This normally indicates something is not correct with the wiring.
Don't use the S02 input.
Can you post the datalog?
eastbethelboy
Re: afr logging?
Im not using the secondary o2 input. I have the white wire from my aem running to b29(egrl) and closed loop set to (egrl) still no luck. Im not with the customer right now so i cant log
eastbethelboy
lambda overlay
ok what I meant to say was my lambda overlay is not working. can someone look at my settings and tell me what im doing wrong?
eastbethelboy
Re: afr logging?
no help from anyone? not even hondata? I sent a log and calibration to a hondata spokes person via-email and he said everything im doing is correct.
I have used this same wideband to tune many s300 with success but I cant get it to work with flash pro at all.. CAN ANYONE HELP ME?
pepperdanky
Re: afr logging?
Post by pepperdanky »
Do you have both the datalog and calibration open at the same time? From your screenshot it doesn't look like there is a log open.
