First datalog after cal upload is always blank
FlashPro Manager software
sockr1
Post by sockr1 »
So every time I upload a calibration to my ECU, the first datalog after that is blank. In Flashpro manager, the Flashpro pop up window shows the datalog and it is a large file (25 minute datalog) but when I "Save As" or download the datalog, it goes down to 1kb and no data shows up on any table or graph.
I usually datalog for 1 minute after uploading a cal, then start a new datalog due to this issue. But sometimes I forget and this morning I did a 25 minute datalog and then came back and had no data showing up in Flashpro manager. This is frustrating and I'm wondering if this is an on-going issue.
I have a 2008 Acura TL and bought one of the first Flashpros when it was released for my car...not sure if that makes any difference, and I'm on the latest firmware.
DomGSR-T
Re: First datalog after cal upload is always blank
Post by DomGSR-T »
I just got the exact same thing! also on a 2008 TL-S
datalog0014 2775040bytes
blank file when I try to download, and when I save it it's a 455bytes file and still a blank file.
Are you starting the datalog using the button on the FlashPro?
sockr1
Post by sockr1 »
Hondata wrote:Are you starting the datalog using the button on the FlashPro?
Yes. Everything is run from the flashpro using its button
DomGSR-T
Post by DomGSR-T »
same for me
Gernby
Post by Gernby »
I've been getting a LOT of empty datalogs from eTuning clients over the past few months.
'06 NFR S2000
sockr1
Post by sockr1 »
hondata any update on this? i've heard from quite a few flashpro people now and they are having the same issue with the blank datalogs, which is very frustrating when you do a 30 min log after work and it's blank when you get home
Gernby
Post by Gernby »
I keep forgetting to post about it, but my eTune clients OFTEN send me datalogs that are empty (1KB). When I email them about it, they say that the datalog shows a bigger size in FPM, but they aren't able to view it. It has happened dozens of times recently.
'06 NFR S2000
It works ok for the models I have tested.
To narrow it down, what model do you have, and are you power cycling the ignition after uploading? Also is the upload made via the FlashPro or with the laptop?
sockr1
Post by sockr1 »
Hondata wrote:It works ok for the models I have tested.
2008 acura tl type s (manual)
uploaded via FP unit
Seanix
Post by Seanix »
Any updates on this Hondata, Spunkster??
I've got the same issue. I'm on Flashpro Manager : V1.9.3
2006 honda S2000.
1.9.3 was released in September 2014. You should download the latest version (currently 2.0.1).
