FlashPro Requests
FlashPro Manager software
all-black
Re: FlashPro Requests
Post by all-black »
vtec by gear would be awesome....expecially for turbo cars. different vtec points for the gearing efficiency/ traction
volvo09
Post by volvo09 »
The ability to datalog the rear o2 would be nice to have (Civic Si). Largely useless for tuning, but if it's data isn't total junk it would be useful for troubleshooting / general observation.
robsbp
Post by robsbp »
Flashpro for 2012+ R18 Honda Civic and R20 ILX Please!
Neopoket
Post by Neopoket »
Can you add to the flash pro if you have traction control module you can select if you want retard the timing or take % from boost control duty
thank you
Victor Marrero
Using the boost controller for traction control doesn't work - it is too slow acting.
VitViper
Post by VitViper »
Hondata wrote:Using the boost controller for traction control doesn't work - it is too slow acting.
And with BBG tables tuned properly it's a nonissue... Cylinder drop works great tho... if only we had it..
BTW, on the CRZ, please disable the cat protect logic, I have supercharged customers hitting it...
DomGSR-T
Post by DomGSR-T »
A quick flash of the CEL everytime a knock count is calculated would be great!
chneo1982
Post by chneo1982 »
[2006 Civic Si / Civic Type R] Allow target lambda to be leaner than stoichiometric
--> Could you add this function for asia S2000?
Myrealnameische
Post by Myrealnameische »
robsbp wrote:Flashpro for 2012+ R18 Honda Civic and R20 ILX Please!
Second that !!! for the 2012+ R18 ... I want to supercharge my '13 lx.
#404Civic
y.rivera
Post by y.rivera »
flash pro for 2012 + R18
thesilverbullet
KPro Nitrous Control for FlashPro?
Post by thesilverbullet »
Now that Hondata offers a output mod for boost control on the s2k. why not add the kpro nitrous settings to flashpro manager with an option to the use the same output to control a solenoid?
'23 RDX SH-AWD
'07 S2K w/ JVT header, Berk 3" header back w/ TP Exhaust, AEM V3 CAI & Flashpro
'02 RSX-S w/cai/exhaust/dcrh/kpro - SOLD
thesilverbullet
add kpro's nitrous settings for s2k using new output mod currently used only for boost control
'23 RDX SH-AWD
thesilverbullet
add audible to shift light bluetooth app
'23 RDX SH-AWD
chneo1982
Post by chneo1982 »
Min & max long term trim settings for Asia civic type R FD2 map.
Gernby
Post by Gernby »
The last I read about it, you guys don't plan to enable Alpha-N for FlashPro. If that's still the case, might there be a possibility that you could at least enable some sort of Throttle Tip-In fuel compensation, or something to make tuning for DBW ITB's easier with a MAP based tune?
This is for an S2000.
'06 NFR S2000
