2002 RSX With a K20z3 swap need a base map
Pospeshil
Post by Pospeshil »
I got a 02 RSX and a 09 k20z3 SI in it have a kpro but no base map for the z3 motor
it won't hold Idle and it have stage 1 cams and 520cc inj...
so if I can get a base map for the K20z3 I would love it
I was trying to copy and past from the Flaspro data but the RPM are diffrent
Re: 2002 RSX With a K20z3 swap need a base map
Use a base map for the 05 RSX. Z3 engine is almost identical.
