Acura RDX overboost code
FlashPro Manager software
hypnotini
Post by hypnotini »
Modifications are cpe intake and flashpro.
Seems like my ecu has a "if boost > X then throw code" fault going on, I am looking to see if there is a way around this.
were not running max duty cycle and getting just a bit over 14psi tops with the flashpro and map settings for target are set high enough to read more psi then that.
Let me know if there is any specific information that would diagnose this.
I am including a datalog attachment.
the_wrench116
Re: Acura RDX overboost code
Post by the_wrench116 »
a copy of your tune would help. your data seems normal to me but I could very well have missed a few things.
hypnotini
Post by hypnotini »
Here is my current tune file.
Are you getting a drivetrain protection fuel cut? Does this occur when in sport shift mode only? It is a two cycle error (it will show pending after the first time), so might be hard to track down to the point when it is occurring.
hypnotini
Post by hypnotini »
it doesn't feel like a fuel cut, its pulling pretty hard. I will get some logs in D mode on wednessday and see if it pops up again. its not tripping any check engine lights so far except one time a while back but after clearing that and adjusting tune it just pops up on the datalog. I have other data logs where it is popping up also.
I did get a pop in my exhaust once also, trying to think outside the box if I damaged the cat and maybe its messing with the knock sensor, I am unsure seeing as many other rdx guys are getting 15-17 psi with no codes :-\.
I am stumped atm.
VitViper
Post by VitViper »
@Hondata
I can reduce the boost targets, and the error goes away, but then we're left with an RDX running basically stock boost... kind of shitty.
Can you tell us what ECU part numbers you are using?
hypnotini
Post by hypnotini »
yeah do you want the car ecu and the hondata or just hondata. thanks for chiming in vit.
car ecu do I need to find on car or is it calibration id or cvn #?
hondata fp = fp-rdx-160047
No, it should be 37820-xxx-xxx
hypnotini
Post by hypnotini »
so not the 37805-rwc-a570 calibration id?
when I pick my car up from work today ill get the physical ecu code.
edit* read the faq ill get it today for you.
hypnotini
Post by hypnotini »
ok the rdx ecu# is - 37820 - rwc - a57
It is a boost cut, but the Honda code is very complicated. It looks at both the turbocharger pressure and manifold pressure sensors, there are multiple compensations for throttle position, air temperature & rpm. I can expose the rpm vs map table but the turbocharger table is more difficult. Or I could just expose the minimum ect or rpm value, so effectively the overboost test would be disabled. Would that be ok?
hypnotini
Post by hypnotini »
I would think that woyld be ok. Vits doing the tune work ill shoot him an additional msg
hypnotini
Post by hypnotini »
2 data logs after doing a battery cable ecu reset.
hypnotini
Post by hypnotini »
so what is the next step
