S300 for 37820-P30-T01: Yes or No
ecronic
Post by ecronic »
Hi All
Wanted to confirm if I could use the S300 for the above mentioned ECU part number.
Details of the car:
1995 Delsol VTEC, B16A6
Thanks & Regards
Ecronic
Re: S300 for 37820-P30-T01: Yes or No
Without seeing a picture of the inside of the ECU it is impossible to say for sure.
ecronic
Post by ecronic »
Spunkster wrote:Without seeing a picture of the inside of the ECU it is impossible to say for sure.
Ok, will post one soon. Thanks for replying.
Thanks & Regards
Ecronic
ecronic
Post by ecronic »
Hi Spunkster
Sorry for the delay in replying with the pics of the ECU. Below are the pics I have taken of my ECU...
Thanks & Regards
Ecronic
No it is not compatible. That is not an OBD1 ECU.
ecronic
Post by ecronic »
Spunkster wrote:No it is not compatible. That is not an OBD1 ECU.
Ok, so what do you suggest? Get another ECU? If yes, which do you recommend? Is this an OBD2 or OBD2a ecu?
Current car setup:
1995 Delsol - B16A6 with header/ intake/ ITR exhaust with mugen twin loop box. Has a Kevlar plate stage 2 clutch as well with stock transmission.
Thanks & Regards
Ecronic
excaliburcombo
Post by excaliburcombo »
Get another OBD1 ecu. If not mistaken that OBD2a ecu base on connector connection.
ecronic
Post by ecronic »
excaliburcombo wrote:Get another OBD1 ecu. If not mistaken that OBD2a ecu base on connector connection.
Any idea which ecu would be best?!
Thanks & Regards
Ecronic
ecronic
Post by ecronic »
The hondata site lists my ECU on compatibility list. So why are you suggesting s300 won't work with my ecu?!?
Thanks & Regards
Ecronic
Your ECU is OBD2, not OBD1. the s300 will only work with an OBD1 ECU. You will need to use an adapter harness and a compatible OBD1 ECU from the list.
