s300 help
OriginalGoods
s300 help
Post by OriginalGoods »
Hondata s300-5009
Ok i had this working the other day, i un installed the program while i was clearing out allot from my laptop. Now i cannot connect the s300 to my pc. I am using windows 7.
Things i tried
-Cheking in device manager
-Update drivers / wont work error code comes up
-Tried older version of smanager
-I can hear the usb connect to computer
-Stays in offline mode
-Green light is on
Any help or suggestions ? should i update my windows ?...
OriginalGoods
Re: s300 help
this is the best i can get it says drivers installed. wont do anything
this is device drivers
Lazysk8r2
Re: s300 help
Post by Lazysk8r2 »
try a different USB port and install usb drivers
Street Tuner/Dyno Tuner
OriginalGoods
Re: s300 help
i tried both of that and it still does not connect
OriginalGoods
Re: s300 help
The battery on the laptop died after i uploaded to s300 and had the car running.
I found these while while i was following the information from this site.
USB Driver - General Fix for Problems - Windows 7 Help Forums
I will be removing all faded sections and trying again. Hopefully this works and others can try it out i will report later.
i ended up getting the driver installed and was able to datalog. Thanks much for the reply and help.
Re: s300 help
Try a friend's laptop and see if that works. If it does then there is a problem with your operating system. Perhaps you accidentally deleted some windows files.
