Throttle Plate vs Throttle Pedal
FlashPro Manager software
ran
Post by ran »
Hi,
I have encountered my throttle plate closing at high rpm ( 8400 onwards ).
Even though my pedal is at 100%.
It is fustrating as power is dropping after 8400rpm.
I am using J37 Throttle body.
Civic type R- asia model.
I attached the datalog for anyone who can help me on this.
Thank you
R-12914
Re: Throttle Plate vs Throttle Pedal
Post by R-12914 »
Hi,
what is your entry in "Overall Limiter" in "Rev Limits" in the "Rev Limiter" and "Rev Limiter Recover"?
(The recovery rpm should be 0-300 rpm lower than the rev limiter!)
BTW: Please attach your Cal!
2008 Honda Civic TypeR FN2
Rotrex C30-94 supercharged with relocated IAT
Powered by ASNU 092/FP330E fuel pump & ASNU 090/750cc fuel injectors
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
There is probably an error condition which is causing the ECU to close the throttle, but it is too short to trigger the error code.
ran
Post by ran »
My rev limits were original 8800rpm and recover 8600rpm.
I encounter P2101.
After which i limit to 8400rpm rev cut and 8200rpm recover, no issue.
Now i set to 9200rpm rev cut and recover 8900rpm..
so far as long as i change gear at 8400rpm...no issue.
Attached my calibration
P2101 is the throttle body. The calibration will not affect it.
Gernby
Post by Gernby »
I ran into this problem with my ITB's, and solved it by reducing the max throttle position in the table. I found that I had to set the max to 60 in the table, but the datalog still shows the throttle opening to 89%. Of course, I can see that the throttles are actually fully open.
'06 NFR S2000
ran
Post by ran »
Gernby wrote:I ran into this problem with my ITB's, and solved it by reducing the max throttle position in the table. I found that I had to set the max to 60 in the table, but the datalog still shows the throttle opening to 89%. Of course, I can see that the throttles are actually fully open.
Thank you all,
You mean at WOT or 100% Pedal, i set the Throttle map to 60% right?
Gernby
Post by Gernby »
The S2000 may be significantly different in the way the table values get applied, so you will need to experiment with the max value for your car. However, below is a screenshot of my throttle map and resulting datalog. Note that my actual throttle plate is 100% open when it shows 88% in the datalog.
Basically, 60 in the table results in 88 in the datalog, which is 100% on the actual throttle plate.
'06 NFR S2000
