Air/fuel ratio during 2 step / anti lag
bcumbie
Post by bcumbie »
Can a wideband accurately read the air fuel ratio while you are utilizing the anti lag or 2 step?
Re: Air/fuel ratio during 2 step / anti lag
No, during the operation of any rev limiter air is introduced to the exhaust system, so the lambda will show lean.
bcumbie
Post by bcumbie »
Thanks for the fast reply.
boosted crx-r
Post by boosted crx-r »
so how are you suppose to know if the a/f is correct and your not about to destroy a $15,000 motor?? how can we properlly setup the 2 step and not crack cylinders or melt pistons?
shut up and boost it!
If the AF is correct at the same rpm and load as the 2 step, then it will also be correct when the 2 step is operating.
boosted crx-r
thanks for the quick response. just so im clear...even though im pulling timing out it will not affect the a/f no matter how much boost it is building? also what effect would enriching the fuel cause?
The timing doesn't change the AF. Adding fuel will obviously change the AF.
boosted crx-r
would adding fuel along with pulling timing help spool the turbo faster then only pulling timing by itself or is it not worth the added egt temps?
