S2000 / KPro4
afzan
S2000 / KPro4
Post by afzan »
Hi,
I wanted to upgrade my Kpro3 to kpro4 and noticed that the S2000 pages (https://www.hondata.com/kpro_s2000.html & https://www.hondata.com/help/kmanager/i ... 00kpro.htm) still mention needing to use the S2000 OEM primary narrowband for closed loop
is this still the case with kpro4?
Assuming this is fixed in kpro4, can we use PRB calibrations for S2000 use now? is there any benefit?
thanks
Re: S2000 / KPro4
With the S2000 & KPro4 you can use either the factory narrowband or an after market wideband for closed loop operation.
There's no need to run PRB calibrations - the PRA calibrations have all the features of the PRB now.
afzan
Re: S2000 / KPro4
Post by afzan »
Ok great, what settings should be used for an aftermarket wideband (PLX using digital input) for closed loop?
Re: S2000 / KPro4
Add an analog input for the PLX. Set closed loop to external wideband. That's about it.
