Problem after upgrade the kpro 4
Rxanthony77
Post by Rxanthony77 »
Hi I recentedly upgraded the kpro version 4 and I have problem with the car ep3 ever since , my setup is k24a2 with jsrc 750cc injectors. After I upload a boost Kal and the ecu start give me some error codes with including misfired couple cylinders and no reading O2 , and fuel cut off after it reach above 0 psi map boost, which I didn't have these problems b4 the upgrade. Please let me know if I can send the ecu back so you guys can check it out?
Re: Problem after upgrade the kpro 4
Are there any error codes?
What is the serial number on the K-Pro board inside the ECU?
From Help, About what is the version of the software you are using?
Post the calibration you are using as well as a datalog showing the problem.
Rxanthony77
i was using the cal in other as k24a2 jrsc 650cc n 9psi kal, i tried both previous and currently updated but still doing the same,
It is not the ECU or KPro, it is the calibration. Can you post the calibration? What vehicle, market & ECU do you have?
Rxanthony77
I have tried other cals but it does give different error code but most of the time with p0134 code, anyway I will post up the cal that used early on later when I get home, my car is 2003 ep3 with 06 k24a2 motor 04 rsx s tranny jsrc 3.2 pulley, rc750 cc racing header n straight pipe. Short ram intake, it was running fine b4 I upgraded the version 4. I'm thinking it gotta be something to do with ecu, because if it the cal problem and y is happened on almost of the other cals as well, that's just what I'm thinking
Rxanthony77
this is the calibration i used K24A2 - JRSC 650 injectors 3.2 pulley JR headers 9-10 pounds boost 210 torque / 260 hp
Unanswered questions:
What market is the vehicle?
What ECU do you have?
Please post the calibration that you are using.
Rxanthony77
Ok thanks guys, it was something with the calibration setting in the parameter. But It seem to have that error code p0134 all the times, any advice? Can I disable it?
We're asked three times for more information in order to help with your problem.
