REV Lights and Oil Level Warnlamp FN2 Euro
chris87
Post by chris87 »
Hello,
i have installed V1.2.8
The REV Lights doesnt work and the Oil Level Warnlamp. Before i update i have it no problems !
can you fix that ?!
Stoney
Re: REV Lights and Oil Level Warnlamp FN2 Euro
Post by Stoney »
You have uploaded a MAP based " race " tune.
These Tunes do not support the features you mention. Use a MAF based calibration instead
typer86
Post by typer86 »
Hi I am new here in the forum.
I have the same problem like chris.
After switch the FN2 to a MAP based, the REV led's will not be used anymore...
The following is enabled:
Use MAP to determine WOT
If I disable this setting, the REV led's will work?!
Regards,
svec
Post by svec »
Hi
Hondata fix it ?
Regards.
Colvert
Post by Colvert »
If you load a MAF calibration, you wont have this issue
svec
Post by svec »
Colvert wrote:If you load a AFM calibration, you wont have this issue
thx, i know
but i want work with race calibration
R-12914
Post by R-12914 »
svec wrote: thx, i know
In a race calibration you don't have this features (amongst other things)!
If you want this features, you must use a afm calibration or a afm calibration with map fuel tables!
2008 Honda Civic TypeR FN2
Rotrex C30-94 supercharged with relocated IAT
Powered by ASNU 092/FP330E fuel pump & ASNU 090/750cc fuel injectors
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
neomasterxo2
Post by neomasterxo2 »
Hondata could use the engine speed for the shift light
we could choose when the light is red
I'm compressor eaton
I have to be cartographic map
typer86
Post by typer86 »
neomasterxo2 wrote:Hondata could use the engine speed for the shift light
Yes, that would be nice if we can adjust the red rev LED's :-D
neomasterxo2
with map Civic-Si-RSP-7-FI
i recovered rev, oil level and start button
R-12914
Post by R-12914 »
The rev lights are working, but with a modified engine (force induction) the maximum Horsepower is at higher rpms as with a stock FN2 engine (at 7800 rpms).
In most case, the maximum horsepower is at higher rpms.
If we can adjust the revlights by speed at any gear, we are able to adjust it!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
@Hondata:
Any news about this?
Is it possible to chance the revlights vs. speed/rpms in any gear?
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
revlights = shift lights?
As you asking for the rpm to be editable by rpm & gear? In that case, no. The rpm is fixed.
