using alternative vss
Re: using alternative vss
Between power and signal on the sensor. On the datasheet link you provided it has a diagram, and also the recommended resistor value.
http://www.jameco.com/Jameco/Products/ProdDS/512401.pdf
05typeR
Post by 05typeR »
Thanks, I will start working on getting this mounted...unfortunately I don't have a V4 as yet
05typeR
Post by 05typeR »
what watt resistor is best to use?
0.5w?
Adm_rsx
Post by Adm_rsx »
How would I calculate the correct amount of pulses per km or mile ? I have a 1.5 3rd gear ratio and have a 05-06 type S.
I run 255/40/170
Adm_rsx
Post by Adm_rsx »
Oops I hAve a 1.15 ratio 3rd gear not 1.5.....
Any input?
The resistor power rating does not matter.
As for the pulse setting, have a guess or use the default, compare the indicated speed with GPS and then make an adjustment based on the difference.
05typeR
Post by 05typeR »
