S300 v3 not uploading to Ecu
dkirk_tinaek
Post by dkirk_tinaek »
I did everything correctly as far as setting up hondata to my laptop and installing drivers. When I plug in the ecu to labtop it says online but when key is turned to the on position. It doesn't give me the option to upload the ecu any ideas?
Re: S300 v3 not uploading to Ecu
What is the s300 serial number on board inside the ECU?
Who socketed your ECU?
dkirk_tinaek
I'm using the lates software it's a gsr in a 96 civic coupe po6 with hondata s300 v3 34411. I just bought it yesterday and i did register it. But still won't give me the option to upload to ecu and a company in Phx called built by notorious
What is the version of software from Help, About?
dkirk_tinaek
It the most recent version on hondata.com I'll have to check after work is that a big deal though?
Yes it is very important.
dkirk_tinaek
I have 2.2.4
That is not the most recent version of software. Try downloading the most recent version from the downloads section of the website and see if that resolves the issue.
dkirk_tinaek
Wrong meant 4.4
Was this ECU tested by the installer with the s300 in it?
dkirk_tinaek
I'm having get that done today to see if the problem could be the ecu.
dkirk_tinaek
It was a faulty ecu thanks for he help spunkster
