Datalog values
mjalaly
Datalog values
Post by mjalaly »
How do I make a correlation between the map values in this datalog vs psi?? I am trying to figure out why my car keeps trying to stall out when i go into the higher boost range. I assume it is hitting the boost cut but i cannot tell based on the map values.
https://www.dropbox.com/sh/0i7grc1d1v3o ... taANa?dl=0
AREA876
Re: Datalog values
Post by AREA876 »
Post current calibration (skl file) and datalog (s3d file) of problem
mjalaly
Re: Datalog values
Post by mjalaly »
the datalog is int h link above, calibration attached. What i am trying to figure out though is how to read the maps numbers are PSI
AREA876
Re: Datalog values
Post by AREA876 »
Can you post the datalog as a s3d file
mjalaly
Re: Datalog values
Post by mjalaly »
not from Excel, i can do a CSV or something.
mjalaly
Re: Datalog values
Post by mjalaly »
Can any one else interpret the values and let me know how to convert them to psi?
Re: Datalog values
What exactly are you seeing, and what do you think is missing? It sounds like you just need to set the units, for the table under setting and/or for the datalog values under sensors.
