P2227 CEL
FlashPro questions & answers specific to the 2007-2008 US TSX
iselfdevi
P2227 CEL
Post by iselfdevi »
My 2012 tsx keeps getting a P2227 cel code whenever I try to datalog a WOT from 2k to redline. Im fully tuned with supercharged with ct-e with 3.8 pulley. In my attached datalog you will notice my PSI goes from 5 psi to 9 psi instantly and thats when the P2227 code appears. The car still drives ok with i can drive up to redline with the code. Can someone help me with this?
2012 Acura TSX 4cyl 6MT - flashpro - ct-e supercharger - ct-e icebox intake - deatschwerks 550cc injectors - RV6 exhaust/pcd - Vit tuned
Re: P2227 CEL
Can you post a datalog showing the error come on...meaning the error is not on when you start datalogging.
iselfdevi
Re: P2227 CEL
Post by iselfdevi »
That is the datalog it happened on. You'll see where the boost goes from 5 psi to 9 psi in a fraction of a second. It happened right in the middle of the WOT run.
Are you saying that cel codes show up on datalogs?
Re: P2227 CEL
Yes they show up in datalogs, but the error code was on from the start of the datalog. I want to see what is happening just before it comes on.
iselfdevi
Re: P2227 CEL
Post by iselfdevi »
That's odd. I didn't see the CEL come on until my dash started lighting up in the middle of the WOT run. Why did it only show itself during the WOT run? Everything looked fine before the run. No CELs. What going on there?
I guess I have to clear all DTCs on my ecu and try to datalog another WOT?
Side note, When I first started tuning/flashing (3 months ago) with the flashpro, I remember clearing a P2227 code from the ecu but it never displayed itself on my dash board. One day, I just decided to check the error codes feature on the flashpro manager and there it was just sitting there with no warning lights.
Re: P2227 CEL
There should be a release of software you can try tomorrow to see if the error goes away with that.
iselfdevi
Re: P2227 CEL
Post by iselfdevi »
Ok. Looking forward to that.
Re: P2227 CEL
use the software to check for updates as it was released this afternoon.
iselfdevi
Re: P2227 CEL
Post by iselfdevi »
I just updated. While I test this new version in the next day or so, I have attached an old datalog that shows the P2227 error code coming on at the 0:09:16.770s mark.
