advanced protection problem...
patrice
Post by patrice »
hi,
i have a S300 on my EK4 ( B16A2 )
I enabled the advanced protection and i have any problem because don't work perfectly.
when i select MAP < 87 kPa AND Analog 1 < 700°C ( EGT ) it works good when the real value are under of this values and the motor cut.
but i select MAP > 87 kPa AND Analog 1 > 700°C ( EGT ) it doesn't works and the motor don't cut so the real values are over of this values !
i don't know why ?!
thanks
Patrice
Re: advanced protection problem...
Post the calibration and a datalog showing the issue.
patrice
Post by patrice »
see the attachments for the calibration ;-)
carto S300 RM22 - réglage sur banc - SP98 - B.skl
You have not supplied a datalog showing the issue.
patrice
Post by patrice »
Spunkster wrote:You have not supplied a datalog showing the issue.
ok i try to do this in the next days .
patrice
Post by patrice »
i try to do a dataloging and i can see more problems...
Indeed, there are values that do not correspond to those displayed in the display mode!
for my analog input 1 ( EGT ) in the display mode i see the values of the AEM EGT ( 600 - 750°C ) but in the dataloging values they are between -130 / -140° !
So if the ECU sees a negative value (ie below my target) it is normal that the protection is not activated !?
Now why is that?
i can't put the dataloging in attachments, the files are too big !
edit : and i think it worked well before an update !
Either make smaller datalogs, or you can trim them in the graph windows by right clicking and setting new start and end points.
patrice
Post by patrice »
Spunkster wrote:Either make smaller datalogs, or you can trim them in the graph windows by right clicking and setting new start and end points.
ok i tried to setting new start and end points...
datalog 200216-A1.s3d
Have you checked the voltage that your EGT is outputting?
patrice
Post by patrice »
Spunkster wrote:Have you checked the voltage that your EGT is outputting?
The voltage of my EGT is good because in the display of the S300 the values displayed are good and the same of the EGT display !
If in my EGT display the value is approx. 600°C, on the display of S300 is 600°C +-10 ....
According to the datalog you have posted, it looks like the display for the EGT is reading a neg value at all times.
patrice
Post by patrice »
Spunkster wrote:According to the datalog you have posted, it looks like the display for the EGT is reading a neg value at all times.
we are agree for that !
i post 2 news little datalog and video corresponding : ( EGT on display is analog1 )
- data logiciel 230216 :
datalog 230216.s3d
https://youtu.be/OOmXhcfBXS0
- data logiciel 230216-B :
datalog 230216-B.s3d
https://youtu.be/-xH9m84eJCU
bizzarely, in the datalog my RPM are too low and the speed is not possible because i'm stopped !
hum hum !
Did you trim these datalogs?
patrice
Post by patrice »
Spunkster wrote:Did you trim these datalogs?
No it's 2 datalogs differents at 5 minutes intervals .
Must I do re install USB drivers? May be ... ?!
edit : bizzarly, i must to remove a soft on my laptop and i don't see the Hondata s300 in the list of the soft installed !
so i re install Smanager ... i see tomorrow if it's better !
patrice
Post by patrice »
This morning it 's good ! I shall must have a ghost Smanager installed !
I don't understand why ?!
