S300 HELP!!!
TOaJazzy
S300 HELP!!!
Post by TOaJazzy »
Hi, i have a civic ek with a H22A7 engine and turbo charged. Running this on a P28 ecu with Hondata S300 V3. My problem is it cuts the rev limiter in at the vtec engagement point. If i disable vtec it runs perfectly, revs all the way to 7800rpm. But it i enable vtec, it revs to 5500rpm and then hits a limiter, the rev gauge reads 0 and it just goes along about 2000rpm. I have read this happens when the rev limiter kicks in, but what is making it kick in? I have lowered all the vtec requirements, like speed and engine temp and it still does it. Any help is highly appreciated.
Also if i rev slowly passed 5500rpm and then floor it it works fine. It only cuts out if i try and accelerate hard through the Vtec engagement point.
Thanks, Jason
Re: S300 HELP!!!
IT sounds like you have a grounding problem and the ECU is grounding through the VTEC solenoid. Check all your engine bay grounds.
TOaJazzy
Re: S300 HELP!!!
Post by TOaJazzy »
I will check tomorrow. But the vtec was working fine when I had the original ecu plugged in. Nothing has changed except for the ecu change. Could this still point to a grounding problem? Thanks again. Jason.
Re: S300 HELP!!!
Based on your description it is most likely grounds.
TOaJazzy
Re: S300 HELP!!!
Post by TOaJazzy »
Ok will have a look and let you know what I find. Thanks. Jason.
TOaJazzy
Re: S300 HELP!!!
Post by TOaJazzy »
Ok. What sort of grounds should I have? I have the battery which has two earths from it. One to chassis and one to a point on the strut tower where another one bolts to it and runs down to the engine. Should there be anymore? Thanks. Jason.
AREA876
Re: S300 HELP!!!
Post by AREA876 »
Is the vss working?
TOaJazzy
Re: S300 HELP!!!
Post by TOaJazzy »
I have checked all earths and all are good. Even added some more in to try it and it's still doing it. VSS is fine.
TOaJazzy
Re: S300 HELP!!!
Post by TOaJazzy »
here is the datalog file if that helps
AREA876
Re: S300 HELP!!!
Post by AREA876 »
Post current calibration as well
TOaJazzy
Re: S300 HELP!!!
Post by TOaJazzy »
here is the calibration, its based off a calibration from this forum
TOaJazzy
Re: S300 HELP!!!
Post by TOaJazzy »
anyone able to find anything wrong? thanks, Jason
TOaJazzy
Re: S300 HELP!!!
Post by TOaJazzy »
Anyone?
Re: S300 HELP!!!
Have you tried the ECU in a known working vehicle?
TOaJazzy
Re: S300 HELP!!!
Post by TOaJazzy »
This is a known working vehicle. It worked fine on the original ecu.
