Battery Light
Blessed987
Re: Battery Light
Post by Blessed987 »
here's the kal for prb ecu d17a2. when i disable the mutiplexor the ac and temp guage do not work but if i use the vtp as ac input the ac stays on and won't turn off. when i enable multiplexor to normal setting everything works but battery light stays on.
Blessed987
Re: Battery Light
can you help me ?
Re: Battery Light
You have not posted anything.
k20actr.j
Re: Battery Light
Post by k20actr.j »
Hi all.I running my euro civic type-r ep3
Lithium battery super B
http://www.super-b.com/en/product/11//sb12v15p-ec
My ecu k pro v2.
Is this battery fully compatible with k pro ?
Please read all technical specifications.(especially here write "End of
charge voltage 15.2" V)
Could this battery create electric issues on V2 especially injectors?
k20actr.j
Re: Battery Light
Post by k20actr.j »
Answer please?
Re: Battery Light
It could cause problems and not charge properly.
k20actr.j
Re: Battery Light
Post by k20actr.j »
If you mean about condition of battery i have no any issue when take numbers of volts by kpro
Idling 14.2 volt
Stoped engine 13.7 volt.
When switching key engine running easily
Any experience generally lithium batteries?
Re: Battery Light
k20actr.j wrote:Any experience generally lithium batteries?
Yes, they catch on fire a lot. Seriously.
k20actr.j
Re: Battery Light
Post by k20actr.j »
First time I hear something like that.
Many sports cars have by their manufacturer lithium battery with the same specifications.
Thanks.
Blessed987
Re: Battery Light
my calibration and Datalogs are attached, please look at them and tell me what you think, Thanks
Blessed987
Re: Battery Light
and here's another Cold Startup Datalog
