kpro v2 with aem uego
constantinos9
Post by constantinos9 »
Hello,sorry if this topic has been covered again but i would like to ask if is possible to use the aem uego with the Kpro v2 in order to use the wideband for close loop. Or is it not supported in kpro v2 and i will use the uego just as an extra sensor for the gauge afr reading only ?
Thanks in advance
Re: kpro v2 with aem uego
You cannot run in closed loop with an aftermarket wideband and a K-Pro V2. YOu would have to upgrade to a K-Pro V4 in order to do that. If you input it on the V2, you can only datalog it.
