Bring back the strain gauge
rev hard
Post by rev hard »
Ive noticed that a lot of people are going faster and faster on s300 now then before, is there anyway way we can bring back the strain gauge settings in s300 to maybe even further improve times , with the people running the dog boxes?
SPOOLIN
Re: Bring back the strain gauge
Post by SPOOLIN »
perhaps it was taken out because the factory ecu can't process it fast enough?
www.MSSRACING.com
9.29 | 6.20 | 167
rev hard
Post by rev hard »
could a strain gauge with 2.5v be setup using the iat input? to cut ignition? on shifts
It was taken out because there is very limited space in the ECU memory. Since more people are interested in using a strain gauge input we've added back in a timed rev limit for the shift cut.
SPOOLIN
Post by SPOOLIN »
How does that help vs adding back in the strain cut input?
www.MSSRACING.com
9.29 | 6.20 | 167
rev hard
Post by rev hard »
yea how does this help? and how long does it cut for?
It is a strain gauge input.
SPOOLIN
Post by SPOOLIN »
I don't see that in 2.5.3?
www.MSSRACING.com
9.29 | 6.20 | 167
rev hard
Post by rev hard »
this would be great...what voltage does it work on? or need to trigger it? 12v? 5 v? 2.5v?
It has not been released yet. It functions from an off/on input, not voltage.
rev hard
Post by rev hard »
using this cut...how does the timing come back in?..does it slowly come in or does it just go back to the map instantly?
V-Spec race development
Post by V-Spec race development »
What strain gauge brand do u guys recommend? I know it needs to be a digital ones and not voltage activated thanks.
rev hard
Post by rev hard »
Flat shift strain gauge shift knob...has a built in on/off ground signal that is adj for how touchy the trigger is
rev hard wrote:Flat shift strain gauge shift knob...has a built in on/off ground signal that is adj for how touchy the trigger is
I see that they are based in Europe, Are there any dealers in the U.S?
rev hard
Post by rev hard »
yup....speedfactory sells them...jjautowerks...few others
