s300 v1 issue
Jaythizzo
s300 v1 issue
Post by Jaythizzo »
I uploaded the preset p72 map and just revving and holding it between 2k to 3k rpm it surges down to 1k and back up again. It also does this when cruising too when you give it light throttle. I've tried different maps and tried adjusting tps to correct specs. Any ideas? Could it be the ecu? its a p06 auto ecu converted as I was told when I bought the s300. Any suggestions would help.
Re: s300 v1 issue
Have you calibrated the TPS in the software itself?
Jaythizzo
Re: s300 v1 issue
Post by Jaythizzo »
Where in the parameter tab do I do that?
Re: s300 v1 issue
The TPS tab.
Jaythizzo
Re: s300 v1 issue
Post by Jaythizzo »
what settings do I put? My tps is calibrated at .48v and its a 66mm skunk2 throttlebody.
Jaythizzo
Re: s300 v1 issue
Post by Jaythizzo »
Okay I think i kind of figured it out. I need to set the tps from reading from the ecu with tb fully closed and read wot. Is this the correct way to do so? I will try this tomorrow.
Re: s300 v1 issue
Yes, then upload the calibration with those settings.
Jaythizzo
Re: s300 v1 issue
Post by Jaythizzo »
It works! Thanks a lot for pointing me in the right direction. I set the percentage to default and then slow adjust the minimum reading to -4 which helped get rid of that nasty idle when slightly holdng my revs between 2k-3k. Thanks!
