FlashPro Requests
FlashPro Manager software
R-12914
Re: FlashPro Requests
Post by R-12914 »
In additional to the tachometer-upload indicator if we uploading a map, can you make a feature like this:
https://www.youtube.com/watch?v=jJ465JikHvc
I mean only a fast (faster as in the video) turn up and down the rev counter, the coolant temperature gauge and fuel gauge when the ignition switch on!
Many cars have this feature from factory like a gauge check up!
It would be nice if you could define an option here, where we could enable or disable this feature with a hook in the software!
Is that possible?
Thank you!
2008 Honda Civic TypeR FN2
Rotrex C30-94 supercharged with relocated IAT
Powered by ASNU 092/FP330E fuel pump & ASNU 090/750cc fuel injectors
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Stoney
Post by Stoney »
Auto blip on downshift
Stoney
Post by Stoney »
issue with the lambda via dash, when you hold the button and then accelerate, on enrichment on tip in you would expect the needle to fall to show a richer AFR ( 9 ish ;1) however the needle rises to show a leaner AFR then drops back to actual.
myuser
Post by myuser »
New Possibilities / Ideas to FlashPro Manager:
1 - Set Limit Speed procedure without re-Flash, similar to Launch Limiter:
  • * Car stopped, ignition ON and engine OFF;
    * Throttle Pedal at 100%;
    * In/Decrement with cruise control the speed;
    * Show the value in Speed Gauge.
This way making a security feature / vallet park
2 - Launch control with throttle pedal
Launch control without bouncing in the limiter.
Example:
  • * User set the launch control at 5000 rpm;
    * Place first gear, throttle pedal at 100%;
    * VSA warning light turns on confirming that launch control is activated;
    * Throttle plate then opens as the throttle pedal was at 5000 rpm.
This prevents fuel injector cut in the launch control window, and
without bouncing in the limiter. As soon the cluth is release then
throttle pedal return to normal.
3 - Cruise Control Window
Allowing to cruise in a speed window.
Example:
User sets cruise to 50mph and window of 10mph.
This allowing the cruise to be activate in 50 mph and when the velocity starts to
drop in upphill 10mph (from 50mph to 40mph) the engine starts to pull at 40mph.
Insted of start at 49mph to go to 50mph, incresed this window.
4 - Show Specific Sensor in specific gauge
View other important sensors in
Example:
Select sensor in FPM to be display in FPM for example:
  • * Oil Temperature as Coolante Temperature;
    * Oil Pressure or Level as Fuel Guage;
    * VTEC Lights as ECO Lights in Low CAM;
    * AF as Rev Limiter (this is implemented).
As soon it presses the Set in Cruise Control the respective Gauges
show the other sensors.
5 - Speed Limiter without injector cut
Speed Limiter with previous injector decrease.
Example:
The throttle pedal could be to 100% and when it reaches near
the speed limit the fuel injector starts to decrease and limiting the speed, or
throttle plate decrease.
6 - Unlock reverse mirror adjustment as Misc option
When reversing allow to automatic set the mirror in reverse,
this option is available in some models.
Thanks and keep up the excelent work ;)
typer86
Post by typer86 »
It is not a performance improvement but a cool feature:
Easy enable/disable a sport noise mode (popping, crackle exhaust sound) without modify the complete calibration.
(Like the latest Focus RS in sport mode)
For example:
Tuneable sport noise feature:
* rev
* low and/or high load only
* more or less popping/crackle noise (scaling :) )
Try to tune this is currently not possible in flashpro:
https://hondata.com/forum/viewtopic.php?f=28&t=19666
dinoc
Post by dinoc »
Please add the same functionalities to TSX (CL9 and CU2) like the ones you just added to Civic SI:
[2006 Civic Si / 2007+ Civic Type R / 2012+ Si] Added adjustable launch control, full throttle shift, reflash tachometer progress indicator and cruise control lambda display.
• [2013 Civic Si] Added purge parameter
• Fixed diagnostics monitor count being incorrect
Euro Honda Accord CL9
iketh
Post by iketh »
please add cal encryption
iketh
Post by iketh »
please add more precision to VSS output, at least tenths
myuser
Post by myuser »
-Heel and Toe Assist (Auto Blip)
When clutch is pressed under braking, for down-shift, this will increase a specific amount of throttle to raise the rpm in this way provide a smooth entry into the lower gear, reducing engine braking and shocks to the transmission. Only available above 40 kmph like Cruise Control.
- Throttle Pedal WOT Correction
In WOT if the pedal is equal or above 97%(reference value) the log/ECU will show/place 100% TPedal and the TPlate will show 100%, instead of... for example: 98% TPedal and 102% TPlate showed on log. If the driver is setting the foot down to 97% or 98% the ECU will read TPedal setting only in the last column... 100%.
- Acceleration time to 0-60 mph / 0-100 kmph
After doing the launch, show the time in the Rev counter.
Example:
After launch, by pressing ReSelect in Cruise Control, Cruise Main Off and break pedal, shows 6.5 rpm's meeaning that the time after desengaging the clutch until the speed of 60 mph / 100 kmp was 6.5 seconds. Only time below 9s is considered.
- Check ECU map version
Possibility to verify/check the map version last uploaded to the ECU.
In this way you get tho see the latest map that was uploaded to the ECU and to FP.
Example: In Calibrations a field with the ECU Last Calibration: «File Name».
Kennyb01
Post by Kennyb01 »
Would love blip on downshift ie rev matching
urbinac27
Post by urbinac27 »
Hi There,
I wanted to see if the Gear ratio adjustment can be added for the 2012+ civic si? Many people i know currently use the K 20 gear-x/Mfactory gear set causing the Speedometer not to function properly unless a dakota digital box is added.
dinoc
Post by dinoc »
Yes, we want this for the TSX CL9 also, please.
sass
Post by sass »
Hondata calibration Civic 2017 blocked from viewing?
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
Not a request, not a bug.
iselfdevi
Post by iselfdevi »
2009-2014 tsx cu2
The ability to lock the VTC angle between shifts.
2012 Acura TSX 4cyl 6MT - flashpro - ct-e supercharger - ct-e icebox intake - deatschwerks 550cc injectors - RV6 exhaust/pcd - Vit tuned
