KManager serial output function enable
amoras10
Post by amoras10 »
Hello,
I have PRB ECU with hondata v4, latest Kmanager software.
Problem 1:
I was trying to connect external dash on serial outputs, i have also found in hondata help:
https://www.hondata.com/help/kmanager/i ... output.htm
Software Setting
• In KManager under Parameters, Multiplexer select the 'Datalogger Output' option.
There is no such option like Datalogger, there is two only: normal, disable.
Any solution>?
Problem 2:
Packet Description,
Is there any possibility to get fuel level packets, what is the bytes sum (asking because software has such displays).
Thanks for support and help.
Re: KManager serial output function enable
What dash are you trying to connect?
amoras10
Post by amoras10 »
its a custom made display.
And we have prepared it to recive through serial output.
But how to enable in hondata serial outpout?
as described in hondata help it doest work, no such fuction in table.
fonzeka
Post by fonzeka »
Are you using a PRB calibration?
amoras10
Post by amoras10 »
yes im using PRB
There are two ways to do this. You can use the ECU multiplexer output, which is a serial stream ('Multiplexer, Datalogger (xxxx bps)'). Or you can use the KPro4 serial output (RS232 or TTL level) - 'Digital Output' on the multiplexer screen. I'd use the KPro4 output.
