Hondata s300 with Glowshift Wideband Air/Fuel Ratio Gauge
GrabberBlueEG
Hi everyone. I have a Hondata s300 and I'm wanting to Datalog A/F Ratios with the Wideband that I have. Under the Digital Input/Output Section in the Parameters there are options for other Wideband Gauges, but the Glowshift Wideband isn't available. I'm wondering if I can use this gauge using analog inputs? If so, is it any different then using any other gauges? If anyone can help me out with this, I'd be more then thankful!
GrabberBlueEG
Re: Hondata s300 with Glowshift Wideband Air/Fuel Ratio Gauge
I have the gauge datalogging to the ECU now, but the only thing is, I can't find the "Custom Input" values that I should put in under "Analog Inputs" at the bottom. Glowshift uses a Bosch 4.9 LSU Wideband Oxygen Sensor, and I can't find the 0v to Lambda, and the 5v to Lambda. Anyone know where id be able to find this?
I've looked on the bosch website and still can't find anything in this document..
http://www.bosch-motorsport.com/media/c ... 659pdf.pdf
The sensor does not output the voltage - the wideband controller does. Contact Glowshift and ask them what the voltage is.
GrabberBlueEG
Ahhhh, thank you very much! I'll post Info below for future reference if other people use this same setup.
GrabberBlueEG
The GlowShift Datalogger Voltages are as followed
0v - 0.68La
5v - 1.35La
I'm still having issues and maybe its something i'm doing? I have the voltage offset at 0 and my Custom Input Values are 0v - 0.68La, and 5v - 1.35La ( as they should be ), but it's still not reading properly. The wires coming from my wideband controller are both connected straight to the s300 (analog 0 and ground)
Here is a video of the issue. If anyone can help of knows anything about this, let me know! Thank you!
https://www.youtube.com/watch?v=fjtp9qIUW8Y
0v - 0.68La
5v - 1.35La
The output voltage is the same as the PLX (0V=10:1,5V=20:1). Just use the PLX setting.
How have you wired the wideband controller to the s300? I hope that you did not connect the o2 sensor heater main ground to the analog ground.
Is this still the case? Same for kpro V4?Hondata wrote: Thu Nov 24, 2016 10:18 am The output voltage is the same as the PLX (0V=10:1,5V=20:1). Just use the PLX setting.
