ECU vs wideband AF Reading
FlashPro questions & answers specific to the 2010 CR-Z (US, Euro & Asia)
Matt Dex
Post by Matt Dex »
I did datalog and found out that the AF reading was bit lower than the AF from wideband. Which one is more reliable?
Re: ECU vs wideband AF Reading
Where was the wideband sensor placed? Before or after the cat? Has it been free air calibrated?
Matt Dex
Post by Matt Dex »
It was plugged into the end tip of exhaust during the tuning. From the screen the afr were drawn in a nice smooth line. But when I do the datalog, lambda table show differently (a bit).
Another question is regarding the stock O2 sensors. Os it wideband type or narrowband?
After the cat will read leaner than the stock o2 sensor. Also if the sensor is near the end of the exhaust then care must be taken to ensure it is not reading any outside air. Finally, the stock o2 sensor is wideband.
Matt Dex
Post by Matt Dex »
What if my cat was turbocharged and decated. So basically we not really need a wideband meter. We can rely on lambda from ecu.
