cannot start engine with s300
hkgbmx
Post by hkgbmx »
Hello everyone, I am come from Hong Kong and driving Honda CL1 Euro R (year:2000)
Recently, I cannot start with s300 but honda's Original ECU was fine. it's my s300 dead? (it works before, until i changed ek9 IAVC plug )
engine room spec:
-H22A engine
-H23A Cylinder
-CP Piston
-BC Cam
-BC Camshaft
-koyo Radiator
here are garage adjustment for me before and after.
before:
-disable 99-01 ek9/dc2 IAVC and don't have any plug connected to sensor.(idle rpm around 1200-1400 without A/C)
-cannot adjust Air Condition temperature (sometimes will no A/C function provided)
after:
-still disable IAVC but connected to sensor.
-cannot adjust Air Condition temperature but A/C function works fine.
how can i check? have somebody can help me via teamviewer? thanks a lot!
jackyft
Re: cannot start engine with s300
Post by jackyft »
Maybe you can upload your .skl file. Then can help to check the config.
And check PM~~~
hkgbmx
Post by hkgbmx »
is there any method can check hondata s300 without connection the car?
anyone can help me... please..
Have you discussed these issues with your dealer/tuner?
hkgbmx
Post by hkgbmx »
Spunkster wrote:Have you discussed these issues with your dealer/tuner?
yeah, but this is a long store. Since i bought this car, it works fine with engine light. I have checked via hondata apps it's because haven't plug in IAVC sensor(on the application it display IAVC have non-malfunction- P505x <<something like that).
after that, I have bought IAVC sensor plug on ebay and re-plug it with ECU but cannot start engine anymore..... why...?
It sounds like you have something wired incorrectly in the vehicle. I would recommend that you try the ECU in a known working vehicle to make sure it is not the ECU that is the problem.
hkgbmx
Post by hkgbmx »
Spunkster wrote:It sounds like you have something wired incorrectly in the vehicle. I would recommend that you try the ECU in a known working vehicle to make sure it is not the ECU that is the problem.
this is my slk file with 20second datalog. please help!
hkgbmx
Post by hkgbmx »
I have tried upload prelude(h22a) skl file in ecu. And it can start up, after that I have put my original skl file in ecu it works too!! But idle keep in 500-600rpm and I have tried to put some gas to 2000-3000rpm and release immediately the engine will die.(need restart engine again). However when engine achieve working temperature it works fine but some error code occurs.... (p0123, p0118, p0113)
Also I cannot run up to 2500rpm after occur these error code ,please help....
