Innovate lc-2 question
cityofcaterpillars
Post by cityofcaterpillars »
Using an Innovate lc-2 wideband and cant seem to find the voltage to lambda conversion numbers anywhere. What are you guys using
Re: Innovate lc-2 question
Have you looked at the manual for the LC-2?
cityofcaterpillars
I didn't get one with mine as it was second hand but I found it on the internet. I just got a serial to usb adapter today so I am going to play with log works a little.
Another thing that is happening is that I have to keep adjusting my voltage offsets in SManager. Could this be caused by a bad ground on the lc-2
How exactly do you have it connected.
cityofcaterpillars
I do believe it's spliced into the ground wire on the ecu. I didn't do the initial install. I know it's supposed to go to the thermostat. Didn't know if this could cause iterference
