Mildly built NA B16A3 with P30 ECU
namato40
Post by namato40 »
Hi Forum,
I have a mildly built naturally-aspirated B16A3 from a Del Sol that I need a basemap for. I have checked the Hondata built-in logs and the only B16 built-in maps include forced induction via supercharging or turbocharging.
My build includes:
Stock Del Sol B16A3 OBD1 P30 ECU
Internals:
B16A3 bored .010 over
OEM CTR B16B pistons (.010 over) (higher compression than stock b16a3 ratio)
Stock bottom end beyond pistons.
New bottom end bearings
CTR single crank pulley
Valvetrain:
Supertech dual valve springs for all 16 valves
Supertech titanium retainers for all 16 valves
OEM ITR camshafts and cam gears
Intake:
OEM ITR intake manifold
OEM B16 throttle body
Aftermarket CAI
OEM O2 sensor
Exhaust:
PLM 4-2-1 Toda B-series rep header
Fueling:
OEM 240CC injectors
Walbro 255LPH fuel pump
Transmission:
Exedy replacement clutch
OEM flywheel
NO LSD
If there are any other parts that I did not include they're most likely OEM.
If someone could help me develop a basemap or even give me a basemap that would be much appreciated. I'm completely new to Hondata tuning and could use a guide even after reading the Hondata supplied information with the S300 Manager program and online research.
Please and thank you!
Jun43
Re: Mildly built NA B16A3 with P30 ECU
Post by Jun43 »
I would just run a ITR or CTR stock base map if you are just trying to start the car. You will need a wideband to tune or bring it to a tuner
edit:
https://www.hondata.com/forum/viewtopic ... 16b#p83542
run at your own risk
namato40
Post by namato40 »
Where can I find a CTR/ITR stock basemap?
Jun43
Post by Jun43 »
namato40 wrote: Fri Apr 21, 2017 12:09 pm Where can I find a CTR/ITR stock basemap?
read the edit part
namato40
Post by namato40 »
Didn't see that until after. Thanks!
Zperformance
Post by Zperformance »
I wouldnt run the itr basemap. I noticed it runs higher timing, i would start off with a b16 and add fuel start from there.
namato40
Post by namato40 »
More fuel than the stock amount from B16a or B16B?
