Which ECU Do I need for a 2004 k24a2
Mr Mobsta Man
Post by Mr Mobsta Man »
I read before I started buying things that I needed a rsx type s engine harness but I ending up buying the base model harness without thinking. Aside from needing to lengthen the TPS and MAP sensor wires along with having wiring for an EGR position sensor that I'm not using and the plug for the EVAP solenoid needs swapped to the TSX plug I don't see why the base model harness couldn't work or am I missing something? Also I see when ordering a kpro chipped ecu I have an option of the PND or PRB ecu. Does it matter if I use the base model ECU or the type S? Thanks
Re: Which ECU Do I need for a 2004 k24a2
Are you using a 6-speed transmission?
Mr Mobsta Man
No, 5 speed rt4wd manual transmission from a crv.
You can use the base model harness, but may have some things missing that the awd system may need. You should be able to use Either ECU in this case.
Mr Mobsta Man
Great. Thank you
