E85 Flex Fuel Sensor
GohardOzCu2
Post by GohardOzCu2 »
Hi All, have received my Hondata Flash Pro and now want to run E85 on my 09 Honda Accord Euro M/T ( TSX in the US ) here in Australia. What next please if anyone knows? Thanks.
Re: E85 Flex Fuel Sensor
None of the ECUs supported but the FlashPro accept an ethanol content sensor. You'll have to manually adjust the fuel trim to get the lambda correct.
GohardOzCu2
Thanks for the tech, will have to wire sensor into one of the pins on the ecu connector i assume to connect with my Flash Pro?
Read the post above again. None of the ECUs supported by the FlashPro have a PWM input.
GohardOzCu2
That Lamda fuel trim would not let me do multiple trim points then because the ecu does not have a spare pin.Haltech ecu run in parallel to Honda ecu required for a permanent flex fuel set up.
