FlashProManager 2.6.7.0 & 2.6.8.0
FlashPro Manager software
R-12914
Re: FlashProManager 2.6.7.0 & 2.6.8.0
Post by R-12914 »
typer86 wrote: Fri May 12, 2017 1:17 am Today updated the firmware from 2.6.6.0 to 2.6.8.0
Issue:
The orange LED is very dark after the update! It is hard to see if the log is started or not.
It look like a little "glow" like a old LED.
Please check it.
My Flashpro is ~4 years old without BT
Same here!
2008 Honda Civic TypeR FN2
Rotrex C30-94 supercharged with relocated IAT
Powered by ASNU 092/FP330E fuel pump & ASNU 090/750cc fuel injectors
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
fizeks
Post by fizeks »
R-12914 wrote: Fri May 12, 2017 3:41 am
Issue:
Please check it.
Same here!
can confirm the orange LED is very dark as well ever since the 2.6.8.0 update. could not see if i was datalogging or not. My flashpro is also without BT if that makes a difference.
fizeks
Post by fizeks »
i updated to the 2.6.9.0 flashpro manager earlier today and safe to say that the orange datalog led issue is fixed for me. all back to normal now thanks!
those with the issue should update for the fix.
Arwin21
Post by Arwin21 »
Hi,
after the last update 2.6.9.0. the radiator fan of my Civic Type R FN2 doesn't work.
In the traffic the engine has reached 98°C (!) and the fan has not activated. I'm worried ...
I use the Group N calibration.
Nothing has been changed for the FN2. 98C is not high for coolant - the fan normally will not switch on until the radiator return reaches a certain temperature, no the cylinder head outlet temperature.
Arwin21
Post by Arwin21 »
In Gr.N calibration on the "misc parameter" page there is
Radiator Fan ON 93°C
Radiator Fan OFF 90°C
The fan is switched based on the radiator return temperature (ECT2) and you're looking at the cylinder head outlet temperature (ECT).
