KManager V1-2-0-7
SiK LiL pLaYa
Post by SiK LiL pLaYa »
02SilverSiHB wrote:
SiK LiL pLaYa wrote:
02SilverSiHB wrote: you're joking right? you're asking if the boost control works on NA? :roll:
THat is NOT what I'm asking. I was wondering if the fuel and ignition correction would work on NA as of right now. I know Hondata planned on including this in KPRO so am wondering if this is it or if its something else for NA cars. I guess I should have been more specific.
My BAAAAD.
lol! sorry man..I was like..uhhhhh, wtf?
All good, that was all my badd lol.
MAX POWER 204.3/MAX TORQUE 154.4
1/4 = 14.496
SiK LiL pLaYa
Nevermind my question. I see that this version has IGNITION and FUEL adjustability for NA cars. Thanks HONDATA.
1/4 = 14.496
Razathorn
Post by Razathorn »
I can't imagine that the per gear adjustments would be specific to running boost...
Dominic..
Post by Dominic.. »
Kpro boost controller works in EUro Kpro?
and example valve selonoid from avcr could use with kpro?
k20tuRbo
Post by k20tuRbo »
Can someone help with the install of the solenoid? I already ordered the parts.
also is there a hi low setting? I need to run 20psi at the track, I guess I just need 2 calibrations? :?:
You really need to read the help file. There is a low and high setting, triggered from a switched input.
The solenoid goes between the manifold/turbo outlet (you have a choice) and the top of the wastegate. We'll put up some more pictures shortly.
k20tuRbo
Post by k20tuRbo »
Hondata wrote:You really need to read the help file. There is a low and high setting, triggered from a switched input.
alright thanks
Solenoid Plumbing
Here is how to connect the solenoid for a typical setup.
02SilverSiHB
Post by 02SilverSiHB »
whats up with the foam filter?
07 Si Sedan
locash
Post by locash »
To keep dirt and debris from clogging up the solenoid..
02SilverSiHB wrote:whats up with the foam filter?
02SilverSiHB
locash wrote:To keep dirt and debris from clogging up the solenoid..
ah!
07 Si Sedan
k20tuRbo
Post by k20tuRbo »
that picture helps alot, could you please give us instructions on the wiring?
02SilverSiHB
k20tuRbo wrote:that picture helps alot, could you please give us instructions on the wiring?
I think he mentioned it's in the help file
07 Si Sedan
k20tuRbo
Post by k20tuRbo »
Ok reading it now
02SilverSiHB
open kmanager
click help then contents tab
Then go to Windows and double click to open contents under it
Double click on Parameters Window.
Then scan down to Boost control and select that, it will tell you everything and even show the same pic
07 Si Sedan
