Accel Enrichment?
FlashPro Manager software
El Verdugo
Accel Enrichment?
Post by El Verdugo »
I was looking to adjust this parameter in this 2013 Civic Si that has a Kraftwerks SC, but I can not find it.
I looked in he help menu and it appears there under the Trottle settings but in the actual manager is not there.
I just upgraded from 2.7 to the current Beta version (2.8.1.0) and its not there either.
Let me know if I am looking in the wrong section to find this parameter.
Re: Accel Enrichment?
The help file is generic for all different vehicle types. The 2012-2016 Si does not have this feature.
El Verdugo
Thanks for the clarification, so what would be the work around for those year models?
What is the problem you are having?
El Verdugo
Just need to add like 2-4% more fuel from tip in accel like when the vehicle its at 40mph and 15% tps and then there is a sudden change dramatically in TPS %, need to add a little on that range.
The 2012-2015 Si does not calculate tip in fuel the same was as previous vehicles, so the same tables are not available. You'll have to tune it the best you can.
