Cel 16 no start
Evanowens
Cel 16 no start
Post by Evanowens »
Hello, I followed the flow chart from the crx service manual, and had ended at 45psi at fuel rail, and 12.7 volts at a1, a2, a3 and a5, and 2.5 ohms at each injector. Car drove around the block, pulled back in the garage to address fuel gauge rising to full on its own, now won't start, can't clear code 16. Sound familiar to anyone?
B16 crx, 50trim 440dsm 3inch s300v3. Service manual says replace ecu, JUST got this package from phearable..my stomach sinks at the thought of faulty ecu, can old dry harness issues be the culprit, even though I have power and resistance? I'd love any guidance. Thanks!
Re: Cel 16 no start
What ECU are you using this in?
Do you have a resistor box installed with those injectors?
Evanowens
Re: Cel 16 no start
Post by Evanowens »
Forgive me, p28 usdm, yes resistor box.
Re: Cel 16 no start
Is there fuel and spark?
Evanowens
Re: Cel 16 no start
Post by Evanowens »
Yes to both, 40819 on box
Evanowens
Re: Cel 16 no start
Post by Evanowens »
Loose connection at distributor jumper, cel cleared, car starts. 30 year old harnesses......
