When updating to version 2.6.6.0 does not allow UPLOAD;
Danny Meza
Re: When updating to version 2.6.6.0 does not allow UPLOAD;
Post by Danny Meza »
the first problem is that the louch Control is to go from 6200 to 6500. it does not comply
the second problem is that its maximum RPM is at 8600, it is at 5000 RPM.
The third problem is that the car does not react quickly is very slow
muchas gracias
The only problem in the datalog I see is that the launch control is at 5000 rpm rather than 6500 rpm. Do you have cruise control?
Danny Meza
if you have cruise control, but you are not debauched
Danny Meza
if you have a cruise control, it is not activated
I'm reading that as yes. In that case, switch the cruise control off and then use the up and down buttons to change the launch rpm.
Danny Meza
I will try and write you thanks.
Take it to a fast track to generate the fault in high RPM and to be able to send you data log
Danny Meza
In that case, turn off the cruise control and then use the up and down buttons to change the launch rpm. It's good, if I worked
I will try high rpm and write you
update the program review 2.8.2.0
Thank you
