wibeband install multiple CEL
FlashPro Manager software
herkikile
Post by herkikile »
Ok so im having trouble connecting my wideband gauge to my 2013 r18 civic. I followed the instructions and disabled ELD and tapped into ELD @ A34(green wire in middle of "A" connector).
Now the issue is once I disconnect the factory wire from that pin the cooling fans run wideopen, cel for coolant temp too high and a few others. ive counted the pins multiple times to be sure im in the correct one but something has to be up.
There has gotta be something im missing, any ideas or a ecu pinout diagram would be greatly appreciated.
boosted 2013 civic r18
Re: wibeband install multiple CEL
It sounds like you have the wrong pin. I would recommend that you double check your counting for that pin. According to the Honda service info it should be an orange wire.
herkikile
Post by herkikile »
Spunkster wrote: Mon Jan 22, 2018 5:00 pm It sounds like you have the wrong pin. I would recommend that you double check your counting for that pin. According to the Honda service info it should be an orange wire.
I have an orange wire @ 24 and 9 ?
tried to get the best pictures I could
herkikile
Post by herkikile »
Spunkster wrote: Tue Jan 23, 2018 12:55 pm 2013 Civic A.gif
THANKS MATE! you are a true gentlemen and a scholar
