Please quick help to unlock Flashpro from vehicle!
FlashPro Manager software
R-12914
Post by R-12914 »
Hi Hondata,
i have a problem with the unlocking Flashpro from the vehicle.
I must replace my ECU.
I have ECU return to stock.
Now i would like to unlock Flashpro from my vehicle and the following massages pops up, although I have an internet connection like this:
Please help me quick!
Thanks!
2008 Honda Civic TypeR FN2
Rotrex C30-94 supercharged with relocated IAT
Powered by ASNU 092/FP330E fuel pump & ASNU 090/750cc fuel injectors
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Please quick help to unlock Flashpro from vehicle!
Can you use the 'send support information to Hondata' function?
R-12914
Post by R-12914 »
Hondata wrote: Fri Mar 09, 2018 3:14 pm Can you use the 'send support information to Hondata' function?
Yes, I have just done!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Looks ok from this end. Are you using a mobile device as a hot spot? Sometimes they cause problems.
R-12914
Post by R-12914 »
Hondata wrote: Fri Mar 09, 2018 3:39 pm Looks ok from this end. Are you using a mobile device as a hot spot? Sometimes they cause problems.
No!
I am using wlan via notebook!
Is this a problem?
If i check for internet connection in Flashpro Manager it is ok like this:
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
What is now?
Please solve the problem!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Try again and let me know.
R-12914
Post by R-12914 »
Hondata wrote: Sat Mar 10, 2018 4:46 am Try again and let me know.
Hi,
i tried it, but no differences, same as before!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Can you try again if possible? I need to capture the problem in the log files. Testing here works ok.
R-12914
Post by R-12914 »
Hondata wrote: Sat Mar 10, 2018 10:38 pm Can you try again if possible? I need to capture the problem in the log files. Testing here works ok.
the problem is still there
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
Hello,
I did a little "research" myself.
Here's some information for you so you can hopefully solve the problem your server's side...
I captured the error message returned via HTTP to the FlashPro Manager program.
There seems to be a problem executing an update on the "users" table in your database.
The error is as follows:
1265: Data truncated for column 'obdiivoltage' at row 4744 sql=UPDATE users SET ...
This is the value the "obdiivoltage" column is tried to be updated with:
... , obdiivoltage = '0,00', ...
Of course I did not post the complete SQL command here to not publicy expose my customer data.
I hope this helps you to fix the problem ASAP!
Thanks & Regards
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Yes, that is what my logs shows. It does not like the euro decimal separator. Should be fixed now.
R-12914
Post by R-12914 »
Hello,
thanks for your efforts, but it still does not work.
The error now returned from your web service is as follows:
1064: You have an error in your SQL syntax ...
This seems to be the problem now:
... obdiivoltage = ., ...
Can you please have another look at this?
Thanks & Regards
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
R-12914
Post by R-12914 »
Now it works - thank you!
Is it possible to deactivate the immobilizer in the Flashpro Manager?
If no, can you put in this feature?
Thank you!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
Glad it is working.
We do not want to allow the immobilizer to be disabled in the interests of preventing theft.
