Fuel gauges on supercharged fn2 type r
philjk
Re: Fuel gauges on supercharged fn2 type r
Post by philjk »
Oh ok. I’ll contact the tuners again and see if they’ll send me the unlocked cal. I’ll let you have a look if you think you can sort out the gauges
for me. That would be great.
Cheers
R-12914
Post by R-12914 »
Yes, with pleasure, no problem! :-)
Please let me know!
2008 Honda Civic TypeR FN2
Rotrex C30-94 supercharged with relocated IAT
Powered by ASNU 092/FP330E fuel pump & ASNU 090/750cc fuel injectors
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
philjk
Post by philjk »
Hi, they seem very reluctant to send me the cal. With respect Prob for the same reason you gave. A lot of effort and time goes into tuning. So I sent them this email.
“Can we do a Hybrid tune on my car with AFM and MAP sensor activated but also tune both AFM and MAP fuel tables. Hopefully this should solve the fuel gauge problem. MAF sensor still ignored so no limp mode.
Sounds promising yes?”
This is basically the way you described your cal so I’ve ran it past them.
tiozes
Post by tiozes »
R-12914 wrote: Fri Jan 19, 2018 2:21 pm For clarification:
AFM/MAF-based map (supported):
Fuel display (supported):
(AFM/MAF-based maps are without MAP-Fuel tables.)
Hybrid-based map (supported):
(Hybrid-based maps are with MAP-Fuel tables. In this case MAP-fuel tables are using above 515 mbar manifold air pressure depending on the load condition and below it uses MAF.)
MAP-based calibration (supported)
Race-based map (no longer supported):
Fuel display (not supported):
(On Race Maps the fuel gauge does not read correctly and is not adjustable!)
hi, I have a race map on a fn2 with gt3076r and 1000cc injectors.
to change from race map to regular map using only MAP tables, can I directly copy my fuel tables and ignition from my RACE map to the new map, and would it work well? or change the fuel tables?
any way to make the conversion?
regards
typer86
Post by typer86 »
tiozes wrote: Sun Mar 04, 2018 4:39 pm
regards
Theoretically yes... But I recomment to check the datalog after switching to the RSP based ECU calibration. (The correct one for the FN2)
Dont forget to set => 0 in the fuel section => "use MAP tables"
Additional: WOT Lambda adjustment low and high:
This table is editiable in race calibrations only from col 1 to 10.
In the RSP based you must tune the full table 1 to 20!!
On supercharged applications I have good results with this:
Dont forget to check RPM and MAP pressure! This could be different from each tune. Depending from your tuner...
tiozes
Post by tiozes »
typer86 wrote: Mon Mar 05, 2018 12:28 am
regards
Hi, I have migrated everything I've seen from the RACE map to the regular map, but I do not know if I'm missing anything.
my tuner has disappeared and no one in Spain that provides the service, since everyone wants to tune in from 0, but my car is perfect as well.
If I send you the map, would you be so kind as to review it?
I imagine that after loading the new map I would have to monitor the A / F in case it fails, right?
Greetings and thanks
tiozes
Post by tiozes »
Help please
