Intake Air Temp Sensor Calibration
CHB
Post by CHB »
Hi Hondata,
Is there a way we can calibrate K Series Intake Air Temp Sensor's thermal characteristic if we are to use aftermarket sensor such as the Fast response GM Open Element?
GM IAT sensor has the following 3 points calibration curve
Temperature Ohms
48 degrees F 7000
87 degrees F 1930
146 degrees F 560
Re: Intake Air Temp Sensor Calibration
I'm sorry, but this cannot be changed in the ECU setup. Only an OEM sensor can and should be used.
CHB
Post by CHB »
Okay thanks
