Air temp correction
b20luda
Air temp correction
Post by b20luda »
is this preset? or does it have to be calibrated to my surrounding weather conditions.
It is preset, and should work ok without modifications.
sohc_mshue
Post by sohc_mshue »
with the iat corrections is there a general rule of thumb for setting it up for larger injectors?
IAT correction is independent of the injector size. Stick with the default settings.
Razathorn
Post by Razathorn »
Hondata explained something that may be of use to you. This was on the k series ecu, but I imagine the principal is the same.
I went tuning on a very hot humid day. A few days later, when it was a little cooler, but a lot less humid. I was running a good 2-4 tenths of an a/f point. Hondata explained that the honda ecu doesn't correct for humidity, just temperature. So, I'm guessing, in muggy / really humid conditions, tune a bit richer since you will lean out a little when the humidity returns to normal levels.
I went from 13.2 to 13.6 or 7 in a few places so I obviously fixed it up in my N/A setup... then again, I have a factory wide band in the k series so it was fairly trivial to fix.
Take it or leave it.
sohc_mshue
Hondata wrote:IAT correction is independent of the injector size. Stick with the default settings.
i know technically if your maps are tuned correctly then injector size shouldn't matter, but it has been proven before that with larger injectors IAT correction is somewhat off. I'm guessing it has something to do with how the larger size injectors act differently than smaller injectors...just like how sometimes with really large injectors it is hard to get them to idle right unless they are running fairly rich afr's at idle.
