K20 swap wiring problems
Ryry
Post by Ryry »
Needing some help here.....
Just finished swapping a EK with a JDM k20a, did a custom engine harness to ecu(kpro).
I’m pretty sure I’ve mis wired something somewhere, have 2 codes being thrown and cannot figure out what is causing it.
P0113 IAT high sensor voltage
P1108 barometric pressure high voltage
I have checked the wires to IAT & Map sensors and they are good (+5v & grnd)
except I’m seeing ~4.5v from the ecu to the map sensor signal -A19 pin which should not have voltage with the map sensor unplugged( but does)
Have checked engine/ecu grounds and all seems correct
I’m not sure on the ecu schematic for the different power/ground circuits, could I have something miss landed causing this back feeding?
Re: K20 swap wiring problems
The baro sensor is inside the ECU, so if you are getting an error for that, the ECU may be bad.
Ryry
Post by Ryry »
I’m really hoping it’s not, brand new and just trying to start it up for the first time.
Also, checked the wire continuity for the map sensor- all good
Depended the A19 pin and still see ~4.7v out of the ecu.
No matter what I do (map plugged in/A19 depended) kpro always reads -29in for the engine pressure (not running)
You should try the ECU on a known working vehicle then.
Ryry
Post by Ryry »
Found the problems.....
Had some intermittent connection issues with the IAT,ECT, and MAP sensors, everything was wired correctly.
Found 3 or 4 wires that were badly corroded in the sensor wiring from the original engine harness that I used to build the tucked harness from......all kpro codes cleared.
Lesson learned, use new wiring!
